RCU Forums - View Single Post - E-ignition BEC experiences
Old 04-14-2012 | 11:55 AM
TimBle
Default RE: E-ignition BEC experiences
ORIGINAL: dirtybird
Nothing is said about what frequency you are using. I wouldn't try this on a 72mhz fm system.
It will probably work OK on a 2.4 system but I wonder if its worth the 2 oz it saves.
An ignition system pulls a heavy current for a short period of time while it charges. The average current it pulls that you read on a voltmeter is no indication of what it takes to charge. It may be several amps for a short period of time. This puts a heavy strain on the regulator. It may not be able to supply what the ignition system really needs resulting in a weak spark at high RPM.
Its simply not a good idea.
really.... must be murder on those large scale planes with their 220cc engines running off a lipo through a power box and regulator..
<br type="_moz" />
