RCU Forums - View Single Post - E-ignition BEC experiences
Old 04-14-2012 | 02:37 PM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
Default RE: E-ignition BEC experiences
ORIGINAL: dirtybird
ORIGINAL: TimBle
ORIGINAL: dirtybird
Nothing is said about what frequency you are using. I wouldn't try this on a 72mhz fm system.
It will probably work OK on a 2.4 system but I wonder if its worth the 2 oz it saves.
An ignition system pulls a heavy current for a short period of time while it charges. The average current it pulls that you read on a voltmeter is no indication of what it takes to charge. It may be several amps for a short period of time. This puts a heavy strain on the regulator. It may not be able to supply what the ignition system really needs resulting in a weak spark at high RPM.
Its simply not a good idea.
really.... must be murder on those large scale planes with their 220cc engines running off a lipo through a power box and regulator..
<br type="" />
An aircraft running a lipo with a power box and a regulator is a very poor idea indeed. There are a lot of unnecessary parts to fail there. I notice that the people that do that resort to redundant systems as a matter of choice. Notice the Smart Fly regulator has a fan to keep it cool. What a power waster that is.
There are a number of world class fliers in the club I belong to. A lot of them choose a simple set of A123 batteries with a diode to reduce the voltage on the ignition. Of course they too have redundancy but their overall reliability is much better.
Regulators produce heat. The fan on a Turbo Reg is most likely lighter then a heat sink and draws less then 10MAH. The A123 batteries have the advantage of being able to be charged very quickly were Li-ion can't. I stick with the Li-ions and regulator because I like to have constant voltage to the servos. I wouldn't consider myself a world class pilot ( Maybe regional LOL ) but having servo speed and power changing on me does show up in snaps and point rolls, my timing ends up being different. At the end of the day, I want an airplane that always behaves the same. After 2.4 came out, I stopped using powerboxes. With 72 mhz, it was a way to drive all servos( sometimes up to 13 digitals ) on a seperate power bus to keep RF from getting to the RX via long leads. I may not have needed it at the home field but when one travels to a region of unknown noise floor, its good to have that extra assurance that your airplane is going to work after a 12 hour drive to the contest.
