RE: Quick bind issues
Hi Norman,
one way to save the given cobfiguration is as follows:
-First install the new GC 2.59 but give a diffrent install directory while setup. This will leave the previous version of GC on your system; and still runable
-next, start GC 2.59 and the corresponding RX(s) and save the config to file
-next, do the FW-Updates to the RX(s) and afterwards bind them to the TX module. do it _without_ turning your transmitter ON, use the USB power instead.
-next, load and restore the previously saved confi file(s) to the RX(s)
After that, select the corresonding model memory and switch on the respective model. This works best.
If you load an old config with GC 2.59, it may happen (even wirh rel 2.56 files) that you get an error message. If so, the config can not be converted by GC to the actual level. Then you have to create the config again. If it loads without errors, you can restore that config to the RX(s)
This procedure was explained by Alwin in the german forum. Hope that helps
best wishes
Thomas
