RE: Suggestions on programming Spect DX7 and Eflite Super Cub 25E?
Fellas, thanks for the suggestions.. I got it all straightened out, but went with the standard wing, not flapperon.. Evidently if you choose flapperon you lose the ability to use 2 different flap settings via the 3 way flight mode switch.. (Flap system menu).. So by creating a gear-gear 0/0 mix I was able to get rid of the interaction on the aileron channel.. Havn't actually used the travel adjust page yet to limit throws for differential, but I think I'll be ok with that.. I thought this radio would handle airplane programming a bit better.. seems to be better suited for helicopters (which is what I use it for primarily..)
Thanks again!
