RE: General RC Terms
MosFet, dielectric grease, torsen diff, ball dif, gear diff, open diff, sealed diff, limited slip diff, spool, locked diff, clutch bell, clutch shoes, flywheel, acorn nut, pilot shaft, sg shaft, head button, glow plug, HSN, LSN, idle needle, carb, idle return spring venturi restrictor, tuned pipe, composite pipe, aluminum pipe single chamber, double chamber, triple chamber, ribbed pipe, muffler, stinger, header, manifold, one way bearing, clock spring, recoil, pull start, bump start, bump box, roto-start, gel cell, nimh, nicad, lipo, life, lion, pb, C rating, mah, burst C, continuous C, fast charge, slow charge, trickle charge, balance charge, storage charge, deep cycle, deans plug, bananna plug, balance plug, tamiya plug, traxxas plug, bullet plug, lead cord, solder, flux, soldering gun, soldering iron, tinning, nitro methane, ##%, caster oil, synthetic oil, castor blend, flame out, tire shore, capped tires, slick tires, pin tires, road tires, paddle tires, tractor tires, belted tire, rim lockers, hex hub, hub pin, cv shaft, dog bone, out-drive cups, c-hubs, pillow ball, pivot ball, knuckles, arms, a-arms, swing arms, tie rod, ball end, linkage, disk brake, brake bias, brushed, brush holder, end bell, brush, commutator, armature, mag, motor can, sliver can, brush-less, stator, cogging, heat sink sensor-less, sensored, capacitor, signal wire, KV, #s, gear ratio, tall gearing, short gearing, spur, pinion, slipper clutch, turbine shaft, shock, silicone oil, o-ring, pison, dual piston, dual rate, spring, shock body, threaded shock, shock clips, shock boot, shock shaft, C-clip E-clip, captured pin, bulkhead, upright, shock tower, crank bell linkage, chassis brace, chassis, pan, chassis flex, hold-down, servo, digital servo, coreless servo, indirect servo, potentiometer, servo horn, servo saver, T-bar, friction tube, floating pod, anti-tweak adjustment, pan chassis, stub frame, space frame, bumper, wing, downforce, body clip, lexan, polycarbonate, decals, rattle can, base coat, top coat, nitro mask, dremel, glow plug ignitor, RTR, ARTR, KIT, Roller.
thats about all i can think of at the moment.
