RCU Forums - View Single Post - Converting to IR
Old 04-16-2012 | 09:47 PM
  #33
YHR's Avatar
YHR
Default RE: Converting to IR
The DBC3 is available now and it is plug and play.
THe DBC has an LED flash output, and recoil is done using standard recoil wiring. i,e micro switch on gun, with the DBC supplying the trigger voltage. All DBC equipped tanks can operate a recoil circuit. THey have always been able to. They are also an inteface between HL electronics and a regular RC receiver, allowing you to use a radio of your choice. IF you are tired of the HL channels then buy yourself a 2.4 gHZ radio and never have to worry about channels again
IF you want to save a few bucks and solder up the kit then that is avialable as well.
All details can be found here. Check out the videos to hear what they sound like with a Benedini attached. I also have a demonstration video showing how easy it is to install.
[link=http://battlearmorrc.weebly.com/]Battle Armor RC[/link]
Cheers
