RCU Forums - View Single Post - Baffles in a cowl
Old 04-17-2012 | 01:01 PM
MTK
Default RE: Baffles in a cowl
ORIGINAL: da Rock
BTW, did you know using lower nitro fuel actually can increase your engine temps? Nitro burns cooler than alcohol. Of course, running higher rpm counteracts that. Nothing is dead simple, is it.
This is true even at higher rpm....High nitro requires a richer needle setting. Richer also means richer in oil which carries heat away more efficiently.
