RCU Forums - View Single Post - Lightning Build
Old 04-17-2012 | 09:54 PM
  #342
STEVE HOSNER
Default RE: Lightning Build
Jeff,
It is getting late so I might be missing something that should be very simple.
I'm just starting the fin constructin and I am not clear on FN1 and how it mounts the fin above the stab.
The length of the rib is too long to fit between the tail peice and the former ahead of thr Stab.
Do I need to cut the rib to match the distance between the tail post andd where FN 6 mounts to
the forward former? How far down into the pocket does the fin need to go? I will add the
strenthing carbon covered peice to help with gluing in the stab tube above the tube and glue the tube in
place from below. Do I need to add another strengthing floor for the fin to mount on?
I am sure that there is a good photo that shows all of this. I guess that I just haven't seen it yet.
Thanks for you help Jeff
