RE: MOKI RADIAL Care and Maintenence
I have a new Moki 150. The carb could not be set to allow the engine to run properly. The pulse generator was dry, so I lubed it. I can now get the carb adjusted & the engine runs fine on the ground. Problem is, every time I take off, the engine stops immediately I leave the ground. I am assuming the pulse generator is not working as it should. Re-plumbed the tank & tried new fuel lines. No change. The pulse generator tube is clear & the carb filter is clear.
I have ordered the electric pump. I hope this cures the problem. I am a bit sick at paying so much for an engine that does not work properly. I think my engine test data supplied is the work of fiction.
