ORIGINAL: Vincent
Mike, it's only so the ecu knows when to give you a low batt warning. The turbine doesn't care what you set it too.
Vin...
Vincent, good information. Thanks.
Question: Won't the ECU abort the start up if it thinks the voltage is low because is taught 9.9v and you use a 7.4v ?
Jack
