RCU Forums - View Single Post - How much of a difference does "C" rating actually make??
Old 04-18-2012 | 04:35 PM
Haddi Taha's Avatar
Haddi Taha
Default RE: How much of a difference does
ORIGINAL: The_Shark
problem with alot of people is instead of gearing down to run a higher voltage battery to run more efficiently, is that they keep the gearing the same and overtax the whole system, they then pick up the burnt up R/c go inside and cry about it over the net.
i still like medium KV and medium voltage the best.
Exactly, if u dont gear down a bit, it will over heat the system causing the magic smoke
