RCU Forums - View Single Post - Interference
Thread: Interference
Old 04-18-2012 | 08:15 PM
  #52
microdon2
My Feedback: (47)
Default RE: Interference
Tired Old Man - I don't know if this is an interference problem - this has to do with a lack of spark on a Zenoah 26 with magneto, Champion R27C plug. Bought this used on a Kangke Monocoupe one month ago. Tested the engine and it worked like a top (cranked the engine with my starter). In the past few weeks I've done some work upgrading the plane - I'm still on 72Mhz - replaced the non-pcm receiver for a Futaba R149 DP \ Dual Conversion, PCM. The cowl on this plane is in two parts, and the inner-section can rub against the ignition wires. While working on the plane I noticed one of the ignition wires looked frayed where it was pinched-into it's lead, so I taped that over. Tried staring the engine this morning - no spark. I tried to fix the frayed-wire connection and also re-pinched the ground connection, but still no spark. I read that you might need to get some velocity into the prop flip to build the charge for the spark, so I used the starter - no spark. Would you have any suggestions? I'm assuming that you can see the spark with the plug not seated in the engine but connected to it's lead wire, right? Thanks for any ideas.
Mike
