RE: Removing Aileron
No matter what kind of hinge you have... you must cut the hinges off. Then cut a new slot and glue in new hinges...Of course there is one exception. Big hinges that have a cotter pin as a hinge pin.
Be careful before you cut...Make sure that you have enough room to cut new hinges. and take note where the structure is...that way your not trying to cut into a wing rib
