RE: DLE55 Problem
Hi guys,
I have the same engine and basically the same complaint. I get it to run nicely on the ground but once in the air doing 3D it burbles some at lower throttle settings. It also doensn't idle well below about 1800 RPM. However, it has never deadsticked once in the first 3 gallons. I just want a super clean transition and can't get it.
So, is this just the way they run? Is the solution a DA 50 or 60 or do I need to put a nipple on the diaphram plate and vent it in the fues to avoid air pressure changes. I've read that might help.
Thx
Oh, no gas leaks here.
