RCU Forums - View Single Post - Easy lines & rivets
Old 04-21-2012 | 02:28 AM
TomCrump's Avatar
TomCrump
Default RE: Easy lines & rivets
I was just asking why your method was superior, as you said in post #12.
I tried scribing, and didn't care for it. If it works for you, go for it. There's nothing wrong with the method. I just don't feel that it's "the coolest looking detail that I hav (e) ever seen."
Ken, I plot out my panel line with pencil. I then lay down the .015 tape. http://www.injectorall.com/draftingtapes.htm I spray primer over the tape, usually 2-3 coats. The tape is removed when the primer gets "tacky." By removing the tape then, no glue adhesive is left behind.
Leroy, I like your rivet method. It does a nice job on flush rivets.
