RE: Sig Sealane CG and control throws?
Thank you Lamoilleriver. I appreciate the help. Do you know where the CG is supposed to be? I've read several posts that recomend adding the chines. I was going to try to fly it once then decide what I needed to do. I was planning to do something similar to my Lanier Mariner to make the belly wider and deflect the spray.
Thanks again for the help,
Jim
