RE: Power supply question
I capable enough to convert a power supply. Looks easy enough. My only issue is I don't have a voltage meter. The charger that came with the kit has a dial on it that goes up to 3 amps. If the power supply is 12 volts, 5 amps, will it damage the battery, or will the charger regulate the amperage?<br type="_moz" />
