RCU Forums - View Single Post - Power supply question
Old 04-21-2012 | 03:26 PM
SBOT
Default RE: Power supply question
Right, the charger will only use what it needs. The printer power supply will have a small schematic showing which wire supplies which volts; so a meter is not needed, but you should get one. It doesn't have to be the best you can buy, $10.00 units work just fine.
