ORIGINAL: aa1a
Thank you Lamoilleriver. I appreciate the help. Do you know where the CG is supposed to be? I've read several posts that recomend adding the chines. I was going to try to fly it once then decide what I needed to do. I was planning to do something similar to my Lanier Mariner to make the belly wider and deflect the spray.
Thanks again for the help,
Jim
Back up in the shed in the morning and I will take a peek at the plans again, pretty sure it is right on the main spar, but will get you an exact measurement.
