RE: Spring Starter Lubrication
Actually, ec, the bearing is NOT working during start because the starter is locked to the shaft. It IS working during engine ops as the starter is stationary while the shaft is rotating. It does need good lube, but it only takes a little attention to keep it from messing you and your plane up.
Bedford
