RE: DLE 30 rear carb problems
No mention of setting the needles in the airplane. Did you do that after installation? From your description, the engine sounds lean. How about cooling airflow through the cowl and engine fins? Is that adequate?
How about the plug ... have you replaced the supplied DLE plug with a proven NGK CM-6?
