RE: DLE 30 rear carb problems
Fuel tank venting ?
As in , If the tank isn't vented properly , the engine will run till the tank has so much vacuum that the pump can't overcome it , and then it quits .
About five min. run time till the pump can't overcome the vacuum of the improperly vented tank sounds about right ...........
