RCU Forums - View Single Post - DLE 30 rear carb problems
Old 04-22-2012 | 12:58 PM
ahicks
Default RE: DLE 30 rear carb problems
ORIGINAL: init4fun
Fuel tank venting ?
As in , If the tank isn't vented properly , the engine will run till the tank has so much vacuum that the pump can't overcome it , and then it quits .
About five min. run time till the pump can't overcome the vacuum of the improperly vented tank sounds about right ...........
about as good a guess as I can come up with too!
