RCU Forums - View Single Post - problem starting caldera
Old 04-22-2012 | 02:05 PM
rcenth
Default RE: problem starting caldera
"<span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">You mentioned turning the nut with a wrench.  Are you saying that if you take the pull start off, but do not turn the one way </span>bearing<span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); "> with a wrench to free it up that if you re-installed the pull start the engine would be in a bind?"</span><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">
</span></div><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">Yes, that's correct. </span></div><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">
</span></div><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">"</span><span style="background-color: rgb(251, 252, 255); font-family: Verdana, Arial; font-size: 13px; ">I would remove the pull start then one way bearing.  Remove the glow pug.  The engine should turn freely in this state by hand."</span></div><div><span style="background-color: rgb(251, 252, 255); font-family: Verdana, Arial; font-size: 13px; ">
</span></div><div><span style="background-color: rgb(251, 252, 255); font-family: Verdana, Arial; font-size: 13px; ">If I remove that nut, it has a rod connected to it which turns the engine, then how would I turn it or start the engine? I was trying to test that but, I couldn't figure out how to turn it from the inside I was going to put a screwdriver in there but, decided not to.</span></div><div><span style="background-color: rgb(251, 252, 255); font-family: Verdana, Arial; font-size: 13px; ">
</span></div><div><span style="background-color: rgb(251, 252, 255); font-family: Verdana, Arial; font-size: 13px; ">Anyway it hasn't been doing that problem since I posted earlier but, not sure if it's permanantely fixed or not, will see what happens tomorrow, can't start it right now forgot to put glow plug on charge will have to go home and do that. It's been sitting for a while I just pulled it a few minutes ago just to see if it would pull and isn't stuck, I wonder if that was it the piston just needed seating, or maybe glow plug was too tight maybe trying to start it while it was loose worked. I just hope the engine isn't messed up, it's brand new so I should be able to get it replaced with warranty but, just have to pay for shipping and what-not.</span></div><div><span style="background-color: rgb(251, 252, 255); font-family: Verdana, Arial; font-size: 13px; ">
</span></div>
