RCU Forums - View Single Post - Ignition problem, switch promlem or something else?
Old 04-23-2012 | 04:06 AM
coralcape
Default RE: Ignition problem, switch promlem or something else?
Simple to check if there is a voltage drop in the switch. Place a voltmeter across the input and output of the switch. If there is a drop you will get a reading. If no reading, no drop. Good luck, red
