RE: MOKI RADIAL Care and Maintenence
While on the subject of the pulse air pump, the clear festo tube is cut and blocked on the carb side only. The pump side is left open. I run an APS fuel pump with good results.
After about 1-1/2 gallons of running, I have not noticed any grease leaking from the air pump or tube.
Question: Is it acceptable to see no grease at all leaking from the pump ??????
Thanks - Jaketab
