Slick wants to snap to the right with quick elevator input
Can anyone tell me why my AJ wants to snap right with full elevator. 70" with dle 30. plane flies great holds lines with virtually no mixing...
the only demon I keep seeing is when doing a loop or trying to pick up a sharp upline the plane wants to snap right... instead of pulling straight up it rolls a 1/4-1/3 to the right and pitches off vertical to the right 15-20 degrees.
Its quite consistant with this... and bugs me the most when finishing a loop or trying to square something off... is this a mixing issue, cg, surface, servo issue? kinda confused on how to fix it.
I'm assuming its stalling at high g load... but Ive had planes that you can pull as hard as you want and they don't kick out like this...</p>
