RCU Forums - View Single Post - fuselage length
Old 04-23-2012 | 01:31 PM
mikeh251
Default RE: fuselage length
I thank you for the reply and will check out the link you provided. I have not done that yet, but will soon. I like the way the Se tracks a straight groove and can handle like a trainer when desired. The Fazer is a mild plane on lo rates also, just not as good as the other. I didn't mention in post, but I had to really weigh the fazer aft to get balance as I mounted servos in the rear and moved motor rearward. Anyhow, if I do extend the fuse on next Fazer kit, that should assist in c/g situation also. I will soon be investigating the link provided with more detailed measurements and should be able to get a second kit better than the first.For my personal intended use that is. Thanks again.
