RE: Slick wants to snap to the right with quick elevator input
Its likely a combination of things that are applicable to all makes and models not just 3DHS
Have you checked your incidences? happy with the CG? where is it? Servos need to be tested under load, a no load test is not enough. I would think one EL servo or linkage is not 100%
Its a tested design, its likely something that can be pin pointed fairly quickly.
Yes the other board will likely give feed back at 15X the rate here.
