RE: Ignition problem, switch promlem or something else?
It amazes me that we don't have a lot more trouble with the switches we use. I've taken some apart, and they are a simple slide contact. Your problem is probably caused by setting idle, and the contacts corroded slightly. Can you say WD-40. Good luck, red
