RE: MOKI RADIAL Care and Maintenence
Let me give an update on our new ignition:
It will run on 7.4 to 11.1Volts, meaning you can run 3S LiFe, 2S and 3S LiPo and your "older generation" batteries at the correct voltages, as well.
Consumption is actually DOWN from the Moki ignition. I should have numbers when it comes to engine performance in a few weeks, the Moki S250 tests are finished, we are working on the S150 right now.
Adjusting the engine has never been easier as this ignition ignites "scenarios" the stock ignition was not able to handle.
-Götz
