ORIGINAL: Pa-18cub150
Ok I am setting up my first gas Engine, a Zenoah g38 and I have a question or two about the fuel line setup. I have 1/8” Tygon Tubing. My question is what size brass tubing should I use?
1/8”brass tubing seems a bit small should I use solder on 1/8” fuel line barbs or get larger brass tubing?
Is a felt fuel pickup clunk a good idea?
I have a Du-bro Gas tank stopper.
Use the fuel line barbs and use light tie wire to lock the fuel lines on. Use a walbro filter pickup, will stop air bubbles being drawn up, thats why they are used in weedeaters and chain saws. The Dubro gas fuel stoppers leak over time, thats why I started making my own fuel tanks.
Cheers
