ORIGINAL: sfarner
Thanks! That helps because my intuition told me that lean was counterclockwise. I'm assuming I rarely need to touch the low speed needle based upon the fact that it looks difficult to get to, correct?
Two other quick ones. First, does the after run get put right into that carb. hole below the high speed needle with the engine off? Second, is it OK to run this for a couple minutes at a time out of the water?
Steve
Yes ARO(after run oil) goes directly into carb you can also put it in the glow plug hole(with glow plug Removed)
Yes it is ok to run the engine for Short Periods without water cooling, If the water jacket is getting To Hot to Touch then you need to stop the engine and let it cool. When the engine is dialed in and Air\Fuel Mixture is Right and Water Cooling, you should be able to touch the water jacket for 2 to 3 seconds before needing to remove your finger from it
