RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Easy way to test this. Close the idle screw all the way. Set up high speed screw to spec. check RPM. Then set up low speed screw for idle. Then check WOT RPM again. If the low speed jet does not add to the WOT then the RPM should not change, either way. I'm not a betting man but if I was I'm saying it is going to change.
