ORIGINAL: RAMFlyer
Thanks for all the suggestions about where to get the velcro but I already have a number of rolls of velcro tape that I will be using. When I use it up I'll try some of the suggested vendors.
I don't think wear will be a problem as the velcro tape is to hold in fuel tanks and, hopefully, I won't need to remove them very often! Just trying to find out which side (hook or loop) is more permanent when glued...
The adhesive is the same on both sides, what you are attaching to will affect its adhesion.
Bare wood is a no no so I suggest you seal it with paint
Alan
