I am going to put my OPS 30 in a Big Kaos.
http://www.rcuniverse.com/forum/m_10986799/tm.htm
It need a spinner. I removed the two studs on the prop hub. I was thinking of using an all aluminum type spinner. I am not enthusiatic about drilling a bunch of holes in the hub or making a new hub that uses multiple prop bolts. What about just using JB weld to glue the hub to the backplate? How about a piece of pliable material between the hub and backplate?
