RCU Forums - View Single Post - AFV Models
Thread: AFV Models
Old 04-27-2012 | 12:16 AM
Triton-50
Default RE: AFV Models
Hey There Derek<div>
</div><div>What happened to the Tiger 1? Lol!</div><div>
</div><div>Sometimes the Hub caps are a tight fit other wise a tiny spot of CA! Cos you might need to take them off!</div><div>Auto etch primer is fine, I think a lot of the guys use auto primer! a lot less expensive!</div><div>I personally prime, assemble, then finish coat them if it's G<u>erman Armour!..</u> just remember not to paint over threads or contact surfaces that may need CA!</div><div>Not sure of the bolt ring? is it a washer? if it is! No glue!</div><div>
</div><div>Hope this helps, I'm sure others will step in with better advice as I'm a Tank virgin! only being doing it since Xmas and  on my second build!</div><div>
</div><div>Cheers from bonnie Scotland</div><div>Stewart</div>
