RCU Forums - View Single Post - E85
Thread: E85
Old 04-28-2012 | 10:19 PM
  #77
flycolorado's Avatar
flycolorado
Default RE: E85
Rdabaghian,
I just converted anolder os 160 Gemini(serial number is in the 600's!)to spark as well. Istarted with 5% nitro fuel and OS F's to get the benchmark (17/6 @ 8200 RPM). Then Itore the motor down so I could drill and tap screw holes for the ignition pickup,replacing all the bearings in the process. Same fuel on spark yielded a 100 RPMincrease (old plugs or 30 degree advance?). I've got the old style air bleed carb so idle is not as spectacular as yours is. Then I mixed up a gallon of E85 w/ 20% Klotz and gave it a whirl. Fired right up andafter Ileaned out the high end about 1/2 turn and got 7800 on the same prop, 8000 was possible but I was worried I was running too lean. Idle was the same, cylinder head temp appeared to be higher as well and it does seem to be sensitive to needle setting. As a test when running nitro, I added a catch can to the crank vent to see how much oil ran through the crank case after an6 oz fuel run, it appeared to be a little less thenan ounce (my ratio right only goes to 2 oz so it was a big guess). After a similar run with the E85 mix I got only about 1/3 the oil in the catch can (due in part to a leaner needle setting I'm sure). That has me slightly concerned that the motor is not receiving enough oil to protect the vitals. I'm on the fence about continuing with the E85. I love the cost, oh and it smells so good when the motor is running. I've got video of the engine running on both fuels, once I get them uploaded I'll post.
