ORIGINAL: Acetronics
" hot air output must be , @ least, twice the input section " ...
Definitely agreed and familiar with the recommendation. Will open up the underside vent if necessary :-)
You could solder the glow heating wire on the connection pin of the glow plug ... I already did it ...
Hmmmm, glow plug replacement would be a task but that doesn't happen often theses days....... I like the idea
You could try the Multiplex " green " plugs ( 6 contacts ) or DB9 or even DB 15 informatics plugs ... often used aboard big scale gliders
and good behaviour against vibes ...
Well those 9 plugs just became 10 plugs (I forgot about the retracts) I've heard good things about the multiplex plugs, I tried a multi-pin connector on my 96" Cessna but removed it after I noticed it not connecting sometimes. the general consensus was that I needed gold plated pins if I wanted a good connection ?????
Your Thoughts
Craig
