RE: Volcano s30 help!
either the diffs are shot, or the slug screw on the drive cups is loose allowing the cups to slip on the input shaft.
those are really the only 2 things...the slug screw is loose or the diff pinion/ring gear is stripped. If its stripped....you can usually hear it grinding/slipping.
