RCU Forums - View Single Post - Tiger Tail M.A.N. Construction Article
Old 04-30-2012 | 08:16 AM
hook57
My Feedback: (21)
Default RE: Tiger Tail M.A.N. Construction Article
Thanks Ralph.
That is what I was thinking would work, just have to find a syringe that will push epoxy through it. I don't want to thin it too much so I was thinking I could heat it a bit (I'll use 90 min epoxy) in order for it to flow better. I'd likely clamp the area then as it is mounted to the fuse. I'll let you know how it turns out.
Jeff, This was my first try using P.U. glue. I admit to the process being somewhat easier to do versus the epoxy (for me). Other than this slight flaw, the rest of the wing surfaces appear to be just fine. I'm not sure what method I'll do next though. Thanks.
Mark
