RCU Forums - View Single Post - Troubleshooting steps if nitro won't start?
Old 04-30-2012 | 04:33 PM
rcenth
Default RE: Troubleshooting steps if nitro won't start?
If the pull start feels too loose is that sign of a possible issue? that was one thing that was in common with those two they pulled really easy. I believe I recall this same issue with one shockwave I had when the exaust manifold had came loose it wouldn't start anymore and pull start seemed quite loose. Like normally when I pull a pull start it feels like there are "notches" as you pull it if it that makes sense but, in these there wasn't it was just like in one really easy pull you can just pull it all the way out without any effort at all. Maybe that means there's no fuel going to the engine? Since if a flooded engine makes the pull start extremly hard where you can't pull it and a "normal" pull start feels like it's in the middle it's not too easy to pull, you have to put your hand on the rc to hold it down and then you put a bit of effort and give it a quick pull not too hard so if there's no effort at all required then could you assume that means there's no fuel going to the engine?<div>
&lt;embed style="left: 0px; top: 0px; width: 0px; height: 0px; position: fixed; display: block; " type="application/rf-np-plugin" id="Siber_embed1"></embed&gt;</div>
