RCU Forums - View Single Post - Tiger Tail M.A.N. Construction Article
Old 04-30-2012 | 06:06 PM
R_G's Avatar
R_G
Default RE: Tiger Tail M.A.N. Construction Article
ORIGINAL: hook57
That is what I was thinking would work, just have to find a syringe that will push epoxy through it. I don't want to thin it too much so I was thinking I could heat it a bit (I'll use 90 min epoxy) in order for it to flow better. I'd likely clamp the area then as it is mounted to the fuse. I'll let you know how it turns out.
Mark,
A glue syringe like this would probably work well. It would require a slightly larger hole than a needle though. The West System epoxy that I've been using lately is very thin. It probably wouldn't need to be thinned any further. Z-Poxy finishing resin is also fairly thin.
RG
