RCU Forums - View Single Post - Volcano s30 pullstart
Old 05-01-2012 | 06:35 PM
nitrosportsandrunner's Avatar
Default RE: Volcano s30 pullstart
if you pull the starter cord and cannot feel the motor rotate fully at least 2 times (per single pull) then the starter is slipping.
sometimes you can pull off the starter (careful, there is a spring that can fall out of the starter case) and clean up the bearing and reinstall the starter and it will work fine again. Sometimes it will even "self clean" if you work the starter enough.
