RCU Forums - View Single Post - Ring Engine Compression
Old 05-02-2012 | 08:45 PM
Ernie Misner's Avatar
Ernie Misner
Default RE: Ring Engine Compression
Wait, there's more! Some ringed engines will appear to have compression when you turn them over in one direction and none or little in the other direction. That's usually the non-pinned rings like in a 4-stroke though and if the gap winds up facing, say to the left, there will be more or less pressure on that side of the piston depending on which direction you are turning the engine over. No kidding!
Ernie Misner
