RCU Forums - View Single Post - BVM Thin O-Ring Lube and UP valves NOT compatible?
Old 05-03-2012 | 04:05 AM
mongo's Avatar
mongo
My Feedback: (15)
Default RE: BVM Thin O-Ring Lube and UP valves NOT compatible?
the up valve seals ARE o rings, or d rings,or cup seals, or whatever up wants to call them. if up has changed their supplier of seals, then, that new material needs to be tested with whatever lube you, or they, think will work.
