RE: G62 muffler install, need advise Please.....
The pipe might or might not change the performance of the engine. I still would run a straight pipe if noise is not a problem, you can't use JB weld and instead of solder use braze. It isn't that hard to make your own header once you get the flange and a few pieces.
