Several issues with brand new Volcano S30
Here is the out-of-box experience. Need help with these issues:
1) Put fresh batteries into the transmitter. Switchedtransmitter to "Power On". "Power LED" does not come on.
2) There are no instructions how to bind transmitter and receiver in the box. Sigh. How do I do it?
3) The picture in the manual on how to set the gear mesh is just so grainy and the arrows are not accurate. Is there a much better picture to clearly show where to insert that strip of paper?
4) The battery compartment cover in the car does not close tightly in the middle even after both screws are all the way in. It bulges up 2 mm. Water could come in.
5) The manual suggests to also loctite the grub screws on the center drive shaft. It seems to be nearly impossible to me to access them from any angle, let alone put them back in with Loctite. Any tips on the best angle?
Thanks so much,
Oliver
