Originally posted by ml3456
The overheating problem ison CH ignition modules. I don't know what 3W uses, but if you contact CH, the will fix the ignition very quickly. Great people to work with.
Mark
Mark
I am aware of the C&H Ignition problem as well.
The problem I mentioned is 3W specific and has documented by several IMAC pilots thus far. Input from 3W reps concur on the temperature problem.
I don't believe there are any issues associated directly with Duralites regulators. I use them, my friends use them without issue at 6V on ignitions.
If you load the voltage after the regulator you'll find the voltage falls down to its nameplate rating. Measuring without a load is deceiving...
