RE: Top Flite p 47, ok for a first plane?
We haven't even determined if the OP wants a small foam P-47, a 40 size, 60 size, electric or a gasser. All of the foam warbirds can be flown successfully following some instructor and simulator time. I'm building a Top FLite P-47 and with flaps, retracts, bomb drop capability, that is definitely not an airplane for a beginner. There is simply too many things to maintain for a novice and too much expense if a mistake is made. I wholeheartedly agree that a Tower Trainer, Avistar, Nexstar or any of the gazillion other high wing trainers is a better choice. Learn to walk before you try running. I have three trainers and have been at this a long time and some days I just enjoy throwing them around. Every RC'er I know has at least one trainer in their fleet. Starting with a tail dragger is also one more obstacle to overcome. For the beginner, a tricycle gear is the best approach. If a scale model is an absolute requirement then one of the high wing Cessnas may be a good choice.
